Integrate other smart bulbs (LIFX, Milight ...)
#1
From Callum on 2014/12/12 01:28:52 +0000
I like the idea of the integration with Phillips Hue. It would be nice if this feature could be extended to work with other smart bulbs like the lifX bulb and it’s accompanying app.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6832732-integrate-other-smart-bulbs-lifx-milight
#2
From Mikael Larsson on 2017/09/21 05:52:39 +0000
Ikea trådfri easy to use support would be great as it will be a solution that many can afford.
#3
From Kevin on 2017/01/11 21:55:40 +0000
+1 for Xiaomi Smart Led Bulb and Lamp (Yeelight), they have an IFTTT channel.
#4
From Alexander on 2016/07/01 09:00:51 +0000
+3 for LIFX
#5
From dragonshardz on 2016/03/21 20:08:59 +0000
Adding my vote for LIFX support.
#6
From Edwin Schmidt on 2016/03/17 19:53:56 +0000
Dear Petr, i think you have Tasker Support. If you have Tasker Support you can easy controll Homeautomatisations like FHEM ( http://fhem.de/fhem.html ).
If you can controll FHEM, there is a lot of Hardware to controll, vom Philips HUE, Milight, FS 10 FS 20 Homematik.
FHEM Lear automatic many Hardware enviroments and should reakt on Tasker, so if Sleep as Android give Tasker a Lead, Tasker can start via FHEM Lights, Coffeemaschine, or the shutter on the Windows. So you donot have to improve everythink in Sleep as android.
#7
From Anonymous on 2016/02/20 10:48:19 +0000
Lifx support please!
#8
From Leo on 2016/01/04 07:32:57 +0000
another vote for milight
#9
From noangel1981 on 2015/11/19 21:12:28 +0000
ge link light bulbs with wink would be great!
#10
From Pedro o Raposo on 2015/10/28 20:10:08 +0000
I've just bought some Misfit Bolt smartbulbs and would love to have them integrated as well.
#11
From Anonymous on 2015/09/26 08:42:58 +0000
I vote for Integrate MiLight - which is cheaper since bulb and bridge are separated. "Mi LIGHT"
#12
From Anonymous on 2015/09/22 13:46:50 +0000
+1 for LIFX support :slight_smile:
#13
From Werner Pieterson on 2015/05/01 21:09:18 +0000
LIFX support FTW!
#14
From Petr Nálevka on 2015/04/14 09:12:05 +0000
+Jorge many thanks we are planning LifX support, but not sure when we will get to it.
#15
From Jorge on 2015/04/13 22:35:43 +0000
Would also like to see Lifx integration, I've worked with the Android API and it's not too bad.
#16
From Mael on 2015/03/04 13:10:16 +0000
Lifx would be great indeed
#17
From Rastislav Švarba on 2015/01/29 11:28:50 +0000
It would be great to have LIFX support. Maybe via LIFX cloud (+ IFTTT).
#18
From Derek on 2014/12/26 01:00:08 +0000
Very much this!
#19
+1 for LIFX support :+1:
#20
Integration for the Kasa App would be great too! IFTTT is a bit messy (and I’m new at it, so I don’t really know what I’m doing).
