Hue smart-light integration does not support controlling more than 7 lights at a time
#1
Sleep As Android will not activate more than 7 bulbs at time. I am using a Gen 1 Hue Bridge, with latest Phillips firmware on all devices. I use 12 Hue lights in my room. (Several fixtures and lamps). I would like the ability for Sleep As Android to automatically turn off all the lights, and when my alarm goes off, exercise the sunrise feature on them as well.
Steps to reproduce:
Configure Sleep As Android to use smartlights, connect to Hue bridge, enable more than 7 lights. Save setting, hit test. No more than 7 lights will activate at a time.
20180818 BETA
