Begin tracking only after no motion is felt for a set time
From Brian Blair on 2017/01/24 13:25:23 +0000
I fall asleep at different lengths of time. Sometimes 20 minutes sometimes 3+ hours. If there was an option to only start tracking after no movement is felt for a specified time then the information would be more accurate. This option should let the user pick the amount of time delay between movements before tracking starts.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/17826532-begin-tracking-only-after-no-motion-is-felt-for-a
From Anonymous on 2017/06/27 06:37:10 +0000
I suggested a similar feature to vibrate a minute or two before a initial default pause runs out, would work best with a wearable so then you can extend the pause another 15-20 mins.
From Anonymous on 2017/03/10 07:37:24 +0000
Your first sleep phase isn't necessarily motionless. So it could not kick in until deeper sleep phases.
I think this would result in less accurate sleep tracking.
