Allow to connect to myfitnesspal and
From Shree Mulay on 2014/11/05 16:58:20 +0000
Should be able to share data with myfitnesspal, withings, fitbit, garmin, jawbone, and other smart apps, so as to exchange data.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6667976-allow-to-connect-to-myfitnesspal-and
From LoneStar on 2016/02/15 21:00:38 +0000
+1 for sync with Garmin Connect
From Dave on 2015/08/08 23:12:08 +0000
Wanna have Withings connected. Would be awesome!!!
From Robin Markowitz on 2015/06/16 01:45:01 +0000
As I understand it My Fitness Pal does not include sleep. It counts calories by logging foods (from a massive database) and subtracts exercise from connected apps so you know how much you can eat. Then you conclude the diary for the day.
If you want to see your sleep along with all your other fitness data, use a fitness "umbrella app" that connects a variety of fitness trackers or even enables manual entry. (Sleep as Android is trying to get Google Fit going with it.)
From Vince on 2015/05/27 07:22:16 +0000
Myfitnesspal, im ok for this. Sleep use energy, so we must use informations about how we sleep. But the connection is not between sleep as android and myfitnesspal but between gamin connect and sleep as android for garmin vivosmart (exemple)
From Arthur on 2015/04/28 08:38:26 +0000
I don't see the point to connect with MyFitnessPal. If someone could explain me how sleep is connected with nutrition…
From Anonymous on 2014/11/18 21:53:46 +0000
Also polar Flow app for the polar activity tracker… and misfit!
