"Alarm icon in status bar" option does not work anymore
#1
The aforementioned option doesn’t work anymore; an alarm icon is now permanently displayed in the status bar and on the lock screen if any alarm is set, regardless of the setting.
20181212 U2
If the option was disabled due to reliability issues on certain Android versions, please check for the specific versions where it causes a problem and only disable it there. Or display a warning to the user that this option may cause reliability issues. On my Android version there were never any issues with this, but now I’ve lost a feature that was very important to me :frowning:
