When disabling a recurring alarm, prompt to auto-resume it on its next scheduled day
Single-Instance Skip / Auto-Resume Prompt for Recurring Alarms
Summary / Overview
Currently, toggling off a recurring alarm completely disables all future occurrences until the user manually turns it back on. This feature requests an interactive prompt when a user toggles off an active recurring alarm, asking if they wish to skip only the next upcoming instance while keeping the remaining repeat schedule active.
Problem Statement
When users have a holiday, take a day off, or go on vacation, they frequently turn off their daily/recurring morning alarm. However, because turning off the alarm completely disables the recurring schedule, users often forget to re-enable it for the next scheduled day, leading to missed alarms and oversleeping.
Proposed Solution & User Flow
User Action:
The user toggles off an active recurring alarm (e.g., a Monday–Friday 6:00 AM alarm) prior to the next scheduled alarm time.
System Response (Prompt):
A pop-up message or bottom banner appears asking:
“Skip next occurrence only?”
“Would you like to turn this alarm back on automatically for [Next Scheduled Day, e.g., Tuesday at 6:00 AM]?”
[ Skip Next Alarm ] [ Turn Off Completely ]
User Selection:
If “Skip Next Alarm” is selected: The alarm remains disabled for the immediate next occurrence, but automatically reactivates for the following scheduled day.
If “Turn Off Completely” is selected: The alarm behaves as it currently does (remains toggled off indefinitely until manually re-enabled).
Expected Behavior
Status Indicator: On the main Alarm tab, the skipped alarm displays a temporary indicator (e.g., “Skipping next: Mon, Sep 21” or a calendar badge) so the user knows it will automatically resume.
Notification Integration: If the upcoming alarm notification is already showing in the notification shade (e.g., “Upcoming Alarm - Mon 6:00 AM”), selecting “Skip” directly from the notification shade should also trigger this auto-resume logic.
Flexibility: Users can tap the skipped alarm at any point before the next cycle to undo the skip or adjust the schedule manually.
Hi @Kat_Mit, you can set the skip until a set date (for example for the duration of your holiday) in the Next alarm section, by tapping on the Date field and picking the next alarm date.
The app also shows the next upcoming date on the alarm card as a status indicator, so you know when the alarm will automatically resume.
In the alarm settings, you can use the “don’t skip” button any time you need to undo the skip (applies to both one-dayskip, or multiple-day skips).
