That is exactly one of our main concerns - the post-alarm wake-up check builds a habit of counting on the “safety” alarm, so you are actually training yourself to go back to sleep after the alarm (and it might be really hard to break such a habit).
@lenka-urbandroid Disagree with you.
Alarmy and Alarm o’clock xtream have the same feature and it is very helpful.
I wish that you add it, or something similar.
Hello @Sadeq_Mohamed , @kn3ck3 @Pavlo @EddieToth & comp. .. sorry this feature took longer, but we have prepared a version of the “Wake up check” feature into current BETA version 20240728.
This APK is available:
https://sleep.urbandroid.org/wp-content/uploads/release/sleep-20240728-beta-release.apk
This version should also soon be available from the BETA channel on the Play Store..
For wake up check you specify two options: Check after.. Time to confirm
Check after means how long after the alarm a notification is shown which asks you whether you really are awake..
Time to confirm the the time you have to say YES, otherwise the alarm will re-activate..
Does this address your feature request? Are missing something in this new feature?
Many thanks for your feedback and for proposing this.
Petr
