Hello, I have an update on the recommended device in this article We finally have a new king of smart watch! - Sleep as Android
Hello, is it possible to support noise colorfit ultra 2. I tried adding the package name of the app but it didnāt work. Could you suggest any other way to connect
Just made the mistake of buying a Mi Band 8 to replace my broken Mi Band 6⦠itās useless.
After jumping through a bunch of hoops to get it working with Sleep as Android Iāve found that no matter what settings I use, it vibrates on connection / re-connection (it seems to drop connection regularly)⦠which basically wakes me up in the middle of the night. As best I can tell, vibration is disabled everywhere, except apparently not!
I guess Iāll be trying to find a cheap Mi Band 6 to ship from China.
Hi @Textuality, the āvibe once connectedā only works for manually started tracking, it is not activated when the tracking resumes the lost connection. Is it possible you are using some other vibration-based feature, like anti-snoring, or lucid dreaming?
No, itās all off. I donāt think this is being caused by SAA, I think itās something to do with Notify.
Whatās odd about the Band 8 (vs Band 6) is that when you start sleep tracking it shows up as a workout on the band. For whatever reason Iāve not had that last an entire night, and when it restarts (I assume after losing connection), the timer resets. Over the nights I was testing it Iād generally wake up to a āworkoutā thatās lasted a couple of hours⦠despite having been asleep for more like 7 or 8.
Screen displayed on band is this when sleep trackingā¦
About Pinetime, howās the accuracy? Compared to other devices, in your experience?
Hi @linyacal2, the accelerometer is providing reliable data. The HR data only works if the HR tracking app is running - so not exactly an optimal configuration. But the data were good.
OK, so Iām not sure what changed, but my Band 8 now seems to be detected just fine and doesnāt have the odd restarts due to seemingly losing connection at night.
Only problem is, the awake detection seems to be overly aggressive and Iām not sure if this is something in SaA, or on the band? Iād like to change the threshold if possible, as whilst Iām not sleeping amazingly at the moment⦠itās nothing like as bad as the SaA graph is making out!
