Hi @vetos,
Is the battery consumption with or without sensors (HR, SpO2)?
You can test the version, it has not been added to the BETA yet, because the impact of the changes was minimal (around 1% per hour).
Hi Lenka - before I installed the APK, Iāve found the last few nights the battery drainage is close to normal (less than 3% per hour).
Theres been no Android update that I can, so not sure if thereās been an update to either of the SAA mobile or WearOs apps. But all looking ok from my end for now.
Hi, I am glad the battery consumption stopped misbehaving, but I wish we knew what was happening. Are you aware of any change? Did the Sleep update, or Wear app?
Uh, no. This hasnāt ever stopped misbehaving. I havenāt been able to record a single complete sleep session because of excessive battery drain for months and I am becoming quite annoyed.
Hi, are you using the latest update? All reports we had were resolved, so we currently do not have any other user reporting battery drain.
What consumption do you see per one tracking? Are HR and SpO2 data collected (by Sleep or other apps)?
