[DONE] Edit/Remove tags
From Sebastian on 2016/12/23 18:35:50 +0000
I have made the mistake of using so many tags that they are overlapping in the graph and now I can’t read anything about it, do I really need to uninstall SaA to get rid of them? & also loose all data? I want a way to remove the tags that I will never use, for example: I’m a man, therefore it’s very unlikely that I will need a menstruation tag, right?
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/17533330-edit-remove-tags
From Dawna Levang on 2017/01/03 14:24:22 +0000
I created tags before realizing there were built-ins and cannot find a menu to delete them. Sebastian's ides would be very helpful!
From Petr Nálevka on 2016/12/28 13:20:04 +0000
Sorry about the limitation, maybe I could suggest a workaround with may require some extra work?
You can use menu - backup - export, look for the file sleep-data/sleep-export.csv edit the csv file and get rid the particular tag from the comment column…
From Sebastian on 2016/12/23 18:37:29 +0000
I know that editing has been suggested before, but not with an concrete example of why it is a problem.
