Vibration Android 6
From Joel on 2017/08/25 16:01:03 +0000
Since I updated to Android 6 I have the problem that the vibration pattern some kind of changed and also that my phones alarm is quieter. I would li9ke to have a possibility to change the vibrationpattern of the alarm to continouse, because this is what realy wakes m up.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/31023412-vibration-android-6
From Joel on 2017/08/28 11:10:38 +0000
I know this, but it would be great to make it possible to customize this.
