[DECLINED] Spire integration
Hi. It will be great if the app was integrate with spire wearable https://spire.io
Spire is a wearable to mainly monitor your breath rhythm. This data could really improve the sleep information, it’s like sonar breath sensor but with a specific hardware.
Thank you. The app is great, keep up the good work! :~)
Unfortunately this device does not provide the required integration options. The device needs to have an API that grants access to adhoc sensor data. Please correct me if I’m wrong, but I believe this device does not have such API. Without public-facing API, there is not much we could do…
