Solution for online radios
One issue that I ever had is about including online radios from my country (Brazil). As we know, it’s not that easy to find the url of the FMs these days, specially if you mostly use smartphones, which is my case.
I suggest the integration with an app like “Simple Radio” that has almost every radio on the map.
I hope you guys can think about it! Thanks for the great app anyway!
Best wishes
