[DECLINED] Rem-fit ZEEQ pillow
Http://rem-fit.com/zeeq/
A pillow with built-in bluetioth, sensors, vibrating capability and speakers.
While they have their own app, it is nowhere near as good as yours and shows no clear way of the two integrating.
Unfortunately, this device does not provide the required integration options. The device needs to have an API that grants access to adhoc sensor data. Please correct me if I’m wrong, but I believe this device does not have such API.
Our app has open API, so any developer of the native app can create the integration with our Sleep:
