Not controlling hue lights since sleep phaser
#1
since i activated my new sleep phaser the app does not control my hue lights anymore.
Steps to reproduce:
setup hue lights, then also setup sleep phaser.
20180818 BETA
#2
I’m also having this issue.
#3
Same issue ever since getting the phaser, would be nice to get the function back so that they activate at same time as the phaser
#4
Any updates please, still doesn’t work with Hue if using Sleep Phaser
#5
i turned off the smart light function for the phaser, now the hue lights are working again, also when using the sensor from the phaser.
