Monitor room temperature
#1
From Suzan on 2014/11/11 03:13:12 +0000
Temperature is a leading cause is sleep loss.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6696768-monitor-room-temperature
#2
From Anonymous on 2017/08/25 04:49:28 +0000
More devices now support temperatures. I have the Garmin vivoactive hr and it includes a thermometer.
Maybe if the third party device that is connected provides a thermometer sensor in its API, check that's available and start using it.
#3
From Aalex Gabi on 2016/10/07 05:45:30 +0000
I think that most phones have battery thermometer.
This week it was really hard to wake up and get up from bed. I slept 10 hours each day although normally I sleep 8. I looked online for reason for which I may have overslept and I found that temperature plays a very important role in sleep.
Then I remembered that I have changed the blanket for a thicker one last weekend. Today I tried using the older blanket and It was amazing: I woke up instantly.
When using the phone's thermometer the temperature will be accurate enough after a hour of stand by because most phones use battery thermometers. For people using bracelets that are capable of recording temperature, the application should read the temperature from the bracelet. The big advantage when using the bracelet is that the temperature under the blanked may be measured if it has an external thermometer and not just the body temperature.
#4
From Joost van den Broek on 2016/06/25 11:39:32 +0000
What about temperature and humidity, since all modern phones support these measurements. Maybe some algorithm which takes battery charge heat in account. My experience is when fully charged, the measured temperature is quite accurate. An manual offset could also be incorporated.
#5
From Anonymous on 2016/05/11 04:45:35 +0000
Could outside temperature be used instead of inside to find statistics about wheater and sleep interaction?
#6
From Elijah on 2016/04/01 19:04:46 +0000
Integrate thermodo with the app
#7
From Trolli.solaris on 2016/01/26 12:39:13 +0000
Today I suggestet the feature "Netatmo data integration". The Netatmo weather station delivers the room temperature, the humidity and CO2-level :slight_smile:
#8
From PaweĊ‚ Polewicz on 2015/10/11 10:23:05 +0000
All devices have a thermometer for their battery. While I doubt this one can give you an accurate absolute measurement, the relative temperature of the battery over a long period of time is probably enough to find out why you can't sleep sometimes.
See http://stackoverflow.com/questions/5974063/how-to-get-battery-temperature-in-android for the API details
#9
From Andy Bryant on 2014/12/10 11:33:56 +0000
Would be excellent if you could integrate temperature (and CO2) data from my Withings smart scales also in my bedroom! This would let me see sleep, temp and CO2 in one app!!!
#10
From Denise on 2014/11/30 22:42:16 +0000
I just wanted to support that idea mabye you could add some support with external devices for retrieving temperature information?
