Improve lucid dreaming and vibration
#1
From Andrew Balashov on 2016/09/21 16:29:17 +0000
Hello to all! I am experienced practicioner of lucid dreaming and have some tips to SaA
  1. Vibration signals in “lucid dreaming” are very slow and shot. Not ever wants only sound signals, i prefer vibro signals, but here they are veary weak. It will be good to add customize for vibro, not only for “lucid dreaming”, but for general alarm too.
  2. The closer the morning, the greater efficiency of LD entering techniques. So it is prefer to skip first 3-4 hours of sleep and give signals then. Nowadays “lucid dreaming” option can give signal even in 30-40 minutes from falled asleep. It will be good to add some customize for it.
With these 2 tips you will improve LD option dramaticaly :slight_smile: ty
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/16289449-improve-lucid-dreaming-and-vibration
#2
From Daniel on 2017/08/13 05:46:14 +0000
I'm using Pebble 2 and for me the vibration is way too strong - I always wake up from it. So I would actually prefer shorter pulses.
Would be great to adjust vibration strength/time and intervals.
#3
From Petr Nálevka on 2016/12/28 11:07:23 +0000
I'm putting option 2 on our todo list…
#4
From Anonymous on 2016/12/25 08:58:12 +0000
Option 2 is great idea and would make a great difference
as I brought this app hopping to have this function
#5
From Paulo Gouveia on 2016/12/19 08:54:56 +0000
The first option is really necessary, especially for deaf people like me.
#6
From Petr Nálevka on 2016/10/10 07:40:51 +0000
+Андрей Суворов, if you configure vibrations on lucid dreaming and you have your watch connected that vibrations will take place on the watch…
#7
From Андрей Суворов on 2016/10/10 06:35:11 +0000
And also it will be great to alarming not on the phone, but on the watch.
