Improve advice regression
#1
Hello, I’d like to suggest two things concerning the regression for giving advice (maximize deep sleep):
  1. For the visualization it would be better to use different symbols for measured data points and fitted curve.
  2. Often only a local maximum is used for the advice, although the value at one of the boundaries is higher.
    Both things should be easy to implement.
Thanks and best wishes.
