Implement smartband from sony (SWR10)
From Jan on 2014/09/23 07:30:32 +0000
…for sleep tracking and to wake with vibration alarm.
I love sleep as android so much, but I use the Smartband from Sony…
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6474138-implement-smartband-from-sony-swr10
From Lars on 2015/12/25 01:24:57 +0000
Petr, any chance of integrating the new smartband 2 SWR12? It has real time heart rate check and if that's not active it checks your BPM 6 times per hour. Would be a reason for me to use the app
From Tom on 2015/03/21 17:31:53 +0000
I don't know much about the process of integrating SWR10 with apps, but maybe this would be helpful?
http://forum.xda-developers.com/showpost.php?p=59508020&postcount=121
From Petr Nálevka on 2015/02/23 09:51:15 +0000
Sorry for that, but I think that at the moment SWR10 does not allow direct access to the sensor. They have an API but this is only to access ex post data aggregated using their algorithms, so not really useful for Sleep as Android. Sorry about that.
We are looking for some reasonably cheap smartband to integrate with, but at the moment there does not seem to be one that could be integrated. We can only offer smartwatches such as Pebble, Wear or Gear…
On the other hand Pebble is quite close to a smartband already, it is very well priced and lasts for 4-5 days without charging with sleep tracking every night
From Daniel on 2015/02/23 03:01:45 +0000
Hi Guys. Any updates on this? I haven't bought your app yet. I'm waiting for this to come.
Cheers
From Johannes Westergren on 2015/01/27 17:49:50 +0000
Please add compability for SWR10! The live-data-issue must be possible to solve?
From Tom on 2015/01/20 14:44:52 +0000
Sony has finally released an API for it, so I hope it will be integrated soon :slight_smile:
From Anonymous on 2014/11/07 07:40:58 +0000
are there already any ideas to interact with the sony smartband?
