Gear S 3 Snoring Vibration Does not work
#1
The feature to engage the vibration when snoring is detected does not work on gear S3 classic. The normal vibration for alarm does work, as other vibrating functions on the watch, so I know this is not a problem with the watch itself. I used to use Wear OS watch (LG Urbaine) and it used to vibrate when snoring was detected and set in the settings… However, gear S3 will not vibrate.
I am a beta tester and I have the latest version pushed, however, I tried this even on regular versions and it still did not work. Would be a nice feature to get working because making audible sounds on phone is not a nice solution for me and my wife.
Can you look into it?
Thanks.
