Compatibility with wearable trackers
From Andrew Lee on 2014/12/01 22:57:38 +0000
Extend wearable compatibility to include fitbit, jawbone and other non smartwatch wearable trackers
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6790424-compatibility-with-wearable-trackers
From Andrea Latos on 2017/04/26 16:58:43 +0000
I have a Misfit Ray which I'd like to integrate. Is this still planned?
From Luke Thomas Barber on 2015/04/27 05:57:01 +0000
Add Garmin vivofit . join the movement. Until then, can't
Use app.
From Petr Nálevka on 2015/04/21 10:22:07 +0000
+JM Fares unfortunately jawbone doe snot give access to the sensors so it cannot be used for integration with SaA… teh API only provides aggregated data ex-post co no use for us…
From JM Fares on 2015/04/19 19:03:30 +0000
Please integrate jawbone, I'm ordering the up3, and they have api for interested devs
From Sebastian on 2015/03/11 16:23:03 +0000
Is it possible to integrate beddit, because he had heart rate and breath.
And he has an Dokumentation about the API ([url=https://github.com/beddit/beddit-api#section-beddit-api[/url]
Thanks
From Petr Nálevka on 2015/02/22 17:50:09 +0000
+Orlando, I'm afraid no 3rd party access to the sensors on smartband…
From Orlando on 2015/02/22 01:12:36 +0000
Is Sony smartband accepting third parties? I would like to investigate how and if it's possible to make this app work with Sony smart band
From Anonymous on 2015/02/07 13:12:28 +0000
How about the Garmin 920xt?
From Salvatore Barba on 2015/02/01 14:42:30 +0000
Please support withings pulse in tracking the sleep.
From Ryan Hermann on 2015/01/26 01:55:15 +0000
Please support the Fitbit Flex!
From Janis Froehlig on 2015/01/22 10:07:36 +0000
Samsung sold a whole lot.of Gear Fits over the holidays, I don't think it's.going away, but between the hard(firm)ware and the API, it seems like the wndeavor would be about as labor-intensive as building a whole new SAA.
From Elizabeth Fraser on 2015/01/22 06:18:26 +0000
Misfit Shine too please
From Lukas Pfannschmidt on 2015/01/19 10:28:24 +0000
Any possibility using this reverse engineered API for the MI Band?http://allmydroids.blogspot.de/2014/12/xiaomi-mi-band-ble-protocol-reverse.html
From Petr Nálevka on 2015/01/17 22:04:33 +0000
Sorry Gear Fit SDK has been pulled and the device product line won't be probably supported…
From Anonymous on 2015/01/17 15:54:32 +0000
Add gear fit
From Vegiair on 2015/01/15 08:40:09 +0000
For Garmin devices help exists here
http://developer.garmin.com/wellness-api/overview/
Would be really great to include them also.
Thanks
From Steven Thomsen-Jones on 2015/01/13 23:35:28 +0000
I see the Sony Watches consumed too much battery but what about the older SmartBand which tracks sleep itself in the LifeLog app. Not sure how the API is though.
From Anonymous on 2015/01/07 22:58:49 +0000
The Nabu and Nabu X seem like interesting devices that have developer portals. Any chance that they may be implemented into the app? Thanks!
From Anonymous on 2015/01/05 14:14:14 +0000
Can Google Fit helps?
