ANT+ Heart Rate Sensor
From Leandro “byLeandroid” Albero on 2015/01/26 19:46:22 +0000
Reopening the entry because of the already implemented support for BT heart rate devices. (Jiri, UrbandroidTeam)
Hi, the idea is to use ANT+ sensor available in most devices and use it to measure BPM using a HRM.
This can be very useful to include a lot of variables in the app.
Thanks.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7013262-ant-heart-rate-sensor
From Anonymous on 2017/07/20 15:11:40 +0000
Please, implement also Ant+ support so this idea can be closed :slight_smile:
From stuart on 2017/06/20 06:04:49 +0000
any plansto add ant+ devices ? app is buggy with bluetooth systems
From Robin Karinen on 2017/06/08 12:08:25 +0000
I understand that it seems like BLE is easier to implement in many apps for developers, but I think more people actually already own ANT+ heart-rate sensors, which have been sold by Garmin for ten years now (Forerunner 305/Edge 305). Sleep as Android requires ANT+ support ASAP!
From Xun Wang on 2017/04/08 17:43:09 +0000
Addendum: not to mention with ANT+ support, one can use the Tempe sensor for temperature monitor. If breathing rate(sonar), motion, HR & temperature can be recorded so easily & cheaply, nothing currently available will come close to SaA for sleep tracking in terms of cost/value.
From Xun Wang on 2017/04/08 17:21:25 +0000
With Newer Garmin watches like mine(Fenix 5x) have "Broadcast Heart Rate" feature from the always on wrist HR sensor, it'll make this feature more useful.
Haven't tested out the sonar yet. If it works well, i can see the ANT+ support for HR from the watch combines with sonar as a very effective "contactless" sleep tracking solution.
From Surya on 2017/03/27 11:23:07 +0000
Ant+ is lower and a super alternative for a low power heart rate sensor. Ant is present on tons of android phones. We should have this support.
From Anonymous on 2017/03/07 06:33:58 +0000
How is this still not supported?
From dunkelfalke on 2016/06/21 22:11:00 +0000
Petre, if you need a phone with ant+ support or an ant+ hrm for development, i can lend you both.
From dunkelfalke on 2016/01/15 16:07:47 +0000
Would really be awesome, there are many people with spare ANT+ hardware around.
ANT+ support is very appreciated! I wish I could help you guys with it.
