Android Auto Problem
#1
Hi,
Since the latest update (end Jan / start Feb) I’ve been having issues using Media Monkey with Android Auto in my Vauxhall. None of the navigation buttons on the main player screen work! I can get into the menu to select playlists, artists, shuffle all, etc, but Play and the forward and back buttons are doing nothing. On the home screen the Play button is also not working.I don’t know whether there’s a fix or whether it can be looked at for the next update please? It certainly only seems to be MM which is affected, none of my other apps are showing any problems.
Please help.
I didn’t find the right solution from the Internet.
References:-
https://www.mediamonkey.com/forum/viewtopic.php?t=89339
Custom explainer studio
Thanks!
#2
Hi - this is not a MediaMonkey forum, this is a site for Sleep as Android.
#3
