Add Spotify, Pandora, etc to alarms
From Jason on 2014/09/30 10:26:33 +0000
(empty description)
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6502632-add-spotify-pandora-etc-to-alarms
From Petr Nálevka on 2016/12/13 09:43:42 +0000
+Lipziger can you please chedule an alarm to trigger in one minute and if the beep beep sound start can you please send a menu - report a bug? Do you have latest Sleep as Android and Spotify, can you idealy install the latest BETA version if not already? Many thanks…
Please note that the problem is not on our end, Spotify does not have an API and it is very problematic to integrate… we need to use a chain of hacks in fact to make this working at least for some…
From Lipziger on 2016/12/13 08:06:11 +0000
As I said in the other suggestion … The spotify ringtone isn'tworking at all :frowning:
From Petr Nálevka on 2016/11/02 09:13:12 +0000
+Miha sorry there no API for Play Music :frowning: so we cannot do much here…
From Miha Rajšter on 2016/11/02 05:23:36 +0000
Possible to add Google Music for us, not living in freedom country :D?
From David Rees on 2015/12/02 19:54:45 +0000
Duplicate of https://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7113291-play-a-spotify-playlist-on-alarm
From Petr Nálevka on 2015/11/27 14:48:24 +0000
@Petr greetings and many thanks. I would love to talk of MMF commercial seminar again, let see :)…
BTW gradual volume does not work yet well with the Spotify integration, we will release a fix for this issue soon…
From Petr Bělohlávek on 2015/11/26 19:27:25 +0000
@Petr This is great not only for the functionality itself (it works really well), but because you guys really listen to what the users want. Please keep this attitude :slight_smile: Btw it would be really nice to see you giving some interesting talk at MFF UK Commercial workshops again.
From Petr Nálevka on 2015/08/16 10:30:33 +0000
As Spotify recently release an Android SDK we will be investigating if this is suitable for alarm wake up
From Jasser Z on 2015/08/15 03:48:01 +0000
The radio isn't that great cause you don't have control of what you will hear the next morning as alarm, but with Spotify we would be able to do that
From Petr Nálevka on 2015/06/07 08:20:35 +0000
+Eli You can add your favorite internet radio into the list, but at the moment we don't support Spotify or Pandora
From Eli Skeggs on 2015/06/07 08:12:50 +0000
I might be missing something obvious, but it doesn't look like either option works with Spotify. The list of internet radios in the app is limited, and I don't think Spotify exposes http streams for their music, and icerrr has the same problem.
From Petr Nalevka on 2014/12/14 10:28:35 +0000
Hello, if you like to test this we prepared integration with the Icerrr app which allows alarm wake up through internet radio, if thsi would also be interesting. The Icerrr app is not yet on the Play Store, but is available from here http://www.rejh.nl/icerrr/ in the settings you need to enable Sleep as Android integration. Please let me know what you think.
Spotify Music Converter form AudFree website is of help to send Spotify songs to alarms. I get MP3 files and add them to alarms.
Spotify musi ccan not be imported to other apps. So I change the format with AudFree Spotify Music Converter and send the music to my devices as a alarms. It works well and I can choose my favorite music. The music is of no quality loss.
I always download songs from Spotify and Pandora and then add them to alarms. For Spotify songs, I usually use a Spotify music converter windows to download them to MP3 and TunesKit Audio Grabber to download Pandora or other streaming music.
